What do the asterisks signify?
vanitymdl
Postby vanitymdl » Thu Jun 16, 2016 9:18 am
I am currently reading the Stock and Watson Methodology for Businesses Cycle indexes, specifically the coincident index. After reading most of their previous work on this study, I can't figure out what the asterisks signify once they introduced the transition equation (pg.7). I know they show what some variables are with the notation, but I want to know the difference between the variables with the asterisks and the ones that do no include the asterisks. Any comments will be greatly appreciated
Stock&Watson 1988.pdf
Stock and Watson paper
(262.36 KiB) Downloaded 352 times
dakila
Re: What do the asterisks signify?
Postby dakila » Fri Jun 17, 2016 4:07 am
It says equation 8 is transition equation, more specifically equation 8 is in VAR(1) form.
In contrast, equation 5 and 6 are AR(p) and VAR(k) respectively. In order to estimate unobservable variable C(t) and u(t), we need transform equation 5 and 6 into VAR(1) form. Otherwise we can't use Kalman filter.
vanitymdl
Postby vanitymdl » Mon Jun 20, 2016 8:15 am
Thank you for the reply, but I am still confused one what is the difference between C(t) and C(t)*?
