Urgent Help..Regression, Taylors Rule
misstee
Postby misstee » Tue Oct 20, 2009 12:06 pm
hello, pls i need help in trying to estimate the yatylors rule regression.
I dont know how to impose the value of b0 b1 and b2 which are 2.5,0.5 and 0.5 respectively. the equation is as thus,
Baserate = 2.5+inflation rate +0.5 (inflationgap) + 0.5(output gap)
pls how do i run this in eviews and how do i get the implied taylors rule interest rates..
Please i would appreciate a timely response
p.s. anybody know any good books for interpreting test results...
trubador
Did you use forum search?
Re: Urgent Help..Regression, Taylors Rule
Postby trubador » Thu Oct 22, 2009 10:09 am
Actually, this is a specific type of equation called "identity". One way to incorporate this into EViews is create an Auto-Updating Series. Suppose that in your workfile you have series named infrate, infgap and outgap, then you can type the following in the command line and generate a series named baserate:
frml baserate = 2.5 + infrate + .5*infgap + .5*outgap
