Probability >1 ?
Francib93
Probability >1 ?
Postby Francib93 » Sat May 21, 2016 2:50 am
Hi guys and thanks for your help. I'm a newbie to EViews so my question may be extremely simple.
I want to model the probability that a firm exports as a function of a set of regressors:
SIZE (Firm size, in thousand employees)
RD INT (Ratio R&D Expenditures over turnover, in percentage)
NORD (a dummy equal to 1 if the firm is located in the North of Italy and 0 otherwise)
By using a sample of 2'172 Italian firms I estimate a Linear Probability and a Probit model whose results are shown in the following tables.
(I just put the LS table since my problem is here)
The professor now ask me to compute this:
Based on the results, compute the probability that a firm exports when it is located in North, it has 5'000 employees and has an RD INT equal to 6%.
My problem is that my probability is higher than 1 and I don't understand why. Am I doing something wrong or the table is wrong? Can you help me with the computation?
Y = 0,21 + (0,018 * 0,06) + (0,059 * 5) + 0,589 = 1,09 !!
I have also troubles understanding the meaning of the coefficients. Since SIZE is in thousand of workers, if I increase by 1000 workers my EXPORT is going to increase by 0,059. (Right?)
RD_INT is a percentage so if I increase by 1% my ratio my EXPORT is going to increase by 0,01% or 1%?
Thanks a lot!!!
Re: Probability >1 ?
Postby startz » Sat May 21, 2016 6:30 am
You've found the problem with a linear probability model, nothing requires the probability to be between zero and one. Using probit fixes the problem.
Francib93
Postby Francib93 » Sat May 21, 2016 7:01 am
Thank you so much! I understand now.
What about the comments on the coefficients? Are they right even if they are not really meaningful?
Postby startz » Sat May 21, 2016 7:05 am
You have the interpretation of the size coefficient right. The other one depends on whether an increase of one percent is coded as 1.0 or as 0.01.
Francib93
Postby Francib93 » Sat May 21, 2016 7:13 am
Thanks a lot really! :D
