Flow control with string variables
londonphd
Postby londonphd » Thu May 12, 2016 11:24 am
Transition from R to Eviews programming has been a little painful, hope someone will help with the following question:
string xd=deter(!i) if %xd="trend" then %xd="d" else %xd="b" endif
here deter is a "string vector", its elements are either "trend" or "cons". I ran the code and it appeared to work, but then the results did not appear to be right.
Thank you.
Re: Flow control with string variables
Postby EViews Gareth » Thu May 12, 2016 12:03 pm
Well, XD and %XD are different things. It looks like you're assigning to XD, but testing %XD.
londonphd
Postby londonphd » Thu May 12, 2016 12:38 pm
Thanks Gareth, I corrected it, works flawlessly. I was following an example where "%" is used, just did not read the details properly.
