HAC Panel Data
stefanp
HAC Panel Data
Postby stefanp » Wed May 11, 2016 1:50 am
Is the HACestimation procedure described at http://www.eviews.com/help/helpintro.ht ... rrors.html available in panel data sets?
Equation Estimation\Panel Options has a Coef covariance drop down menu, but I cannot find the HAC method. Using Eviews 9
Re: HAC Panel Data
Postby EViews Gareth » Wed May 11, 2016 4:31 am
Since it is, econometrically, not a panel procedure, it is not available for panels.
For robust covariance options available in panels, look at the panel robust covariance section:
http://www.eviews.com/help/helpintro.ht ... 23ww187927
stefanp
Re: HAC Panel Data
Postby stefanp » Wed May 11, 2016 7:11 am
I think White period method works for me.
I further need to access the t-stats of the coefficients estimate. However, I end up with a message
"Square root of negative number in "GENR STATS=@TSTATS(3)"
Any ideas what causes the issue?
Re: HAC Panel Data
Postby EViews Gareth » Wed May 11, 2016 7:24 am
Would need to have the work file with the equation in question
stefanp
Re: HAC Panel Data
Postby stefanp » Thu May 12, 2016 12:15 am
I am afraid I cannot upload the workfile here.
However, the estimation itself does not cause any problems. Only the line
STATS=@TSTATS(3)
produces the error message. Without any knowledge of the Eviews "black box" it is hard to understand that as the t-values are computed regardless of the command above. It seems like the assignment of the t-stats to the vector stats is troublesome.
Re: HAC Panel Data
Postby EViews Gareth » Thu May 12, 2016 12:19 am
What's the version/build date of your copy (Help->About EViews)?
stefanp
Re: HAC Panel Data
Postby stefanp » Thu May 12, 2016 2:40 am
Version 9, Nov 2 2015 build
Re: HAC Panel Data
Postby EViews Gareth » Thu May 12, 2016 4:18 am
You should update to the latest version.
