Direct Forecasting
Harvard
Direct Forecasting
Postby Harvard » Wed Nov 19, 2008 3:51 pm
Hello colleagues,
i want to forecast a sample not by iteration, but direct. This means for example, that my AR model looks like this: y(5) c y(-1) y(-2), if the forecast horizon is 5. Because Eviews is not able to forecast it by the commands "fit" or "forecast", I have to program it. Has anybody an idea, how it could look like?
Thanks and greetings
Re: Direct Forecasting
Postby EViews Gareth » Wed Nov 19, 2008 3:54 pm
I don't follow what you mean by this.
You want to estimate Y(5) without estimating Y(4), Y(3), Y(2), Y(1)? If so, then what value do you wish to use for Y(-1) Y(-2)? If you want to use the true values, then a "fit" will do it.
Postby startz » Wed Nov 19, 2008 6:36 pm
Hello colleagues,
Forecast doesn't work with leads and lags. But you could do
series x=y(5) ls x c x(-6) x(-7)
Harvard
Postby Harvard » Wed Nov 19, 2008 11:27 pm
the idea "series x=y(5), ls x c x(-6) x(-7)" sounds great. I will try it and post if it works.
Thanks very much
Harvard
Postby Harvard » Thu Nov 20, 2008 6:11 am
Dear colleagues,
it works.
Thanks again for the great idea.
Greetings from Germany
