I am using the new tool of EViews 9.5 to estimate MIDAS models.
I am wondering if exists a similar tool to estimate Unrestricted MIDAS model (U-MIDAS).
Further, I would like to understand better how I can forecast using the MIDAS function. For instance, I want to forecast (static forecast) a quarterly variable using monthly data. When forecasting, is it possible to update the estimated function for each month of the quarter (i.e. I use the same model every time I am in the first month of the quarter). Finally, can I get dynamic forecasts re-estimating the model for each h horizon? Do I have to do it with a loop?
Thanks,
A.
MIDAS
Re: MIDAS
U-MIDAS is not built in. It wasn't added since it is fairly simple to estimate outside of the MIDAS engine. We've been contemplating adding it nevertheless though.
To do it manually, simply perform point frequency conversion to bring over the observations, and lags of the observations to the lower frequency page.
I'm not sure I understand what you mean by a different model for each month of the quarter, but, yes, using the manual frequency conversion method, it should be possible.
To perform h-step forecasting, you will have to write a for loop, yes.
Since it might be useful, here's a program I wrote to verify that the PDL/Almon MIDAS approach was estimating correctly - it brings over the lags and then creates a polynomial from them. It should give you some pointers on writing a manual U-MIDAS.
!xlags = 4
!ylags=1
!horizon=2
!polyorder = 3
wfopen(wf=midas, page=quarterly) .\mydata.xlsx range="Sheet1"
pageload(page=monthly) .\mydata.xlsx range="Sheet2"
series x1 = dlog(value(-!horizon))*100
for !i=2 to !xlags
series x!i = x1(-!i+1)
for !i=1 to !xlags
series z!i=x!i(-2)
pageselect quarterly
series y = dlog(value)*100
smpl 1985 2009/1/1
for !i=1 to !xlags
copy(c=l) monthly\z!i x!i
for !i=1 to !polyorder
series z!i=0
scalar w!i=0
for !i=1 to !xlags
for !j=1 to !polyorder
z!j = z!j + !i^(!j-1)*x!i
w!j = w!j + !i^(!j-1)
group xlags z*
group ylags
for !i=1 to !ylags
ylags.add y(-!i)
equation eq2.ls y c xlags ylags
show eq2
- mydata.xlsx
- (47.65 KiB) Downloaded 633 times
