predictions
jmmbelbute
predictions
Postby jmmbelbute » Sun Apr 03, 2016 3:58 am
Dear all
I need to build a reference scenario for a variable using an ARFIMA univariate model, estimated for the period 1900-2014.
I’ve already got the in-Sample and out-of-sample forecasts for this period but the reference scenario covers predictions from 2015 to 2050.
Until now I’ve been unable to understand how can I do it using Eviews... :(
Therefore, I would be grateful if I could have any help from you to solve this "problem" :)
Thank you
Regards
Re: predictions
Postby EViews Gareth » Sun Apr 03, 2016 7:07 am
It isn't clear what you're asking.
jmmbelbute
Re: predictions
Postby jmmbelbute » Sun Apr 03, 2016 8:31 am
Thank you for yor reply
For all that matters, I need to get forecasts of x(t) between, say, 2000 and 2100, from a pre-estimated ARFIMA model on x(t), using eviews
It should be noted that I have already estimated the ARFIMA model in e-views.
regards
jmmbelbute
Re: predictions
Postby jmmbelbute » Sun Apr 03, 2016 8:36 am
Please, note also that my sample period for x (t) goes from 1900 to 2014
JMMB
Re: predictions
Postby EViews Gareth » Sun Apr 03, 2016 3:46 pm
Isn't that just a forecast? Just hit the forecast button and change the sample to be whatever you want it to be
jmmbelbute
Re: predictions
Postby jmmbelbute » Mon Apr 04, 2016 1:49 am
That's what I thought...!
Anyway, I ‘ve already done it (I've even expanded the workfile range until 2100) but it still doesn’t work. I'm still getting the in-sample predictions/forecasts (1900-2014), and I don’t know what's missing? Can I send you my workfile?
Re: predictions
Postby EViews Gareth » Mon Apr 04, 2016 4:28 am
You can attach it to a post here
jmmbelbute
Re: predictions
Postby jmmbelbute » Wed Apr 06, 2016 1:49 am
Here is the file with one ARFIMA models estimated in E-Views 9 (64 Bit).
I plan to get forecasts/predictions between 2015 and 2100. I’ve already extended the workfile range until 2100.
I'd be extremely grateful for your help (I’m able to get predictions (out-of sample) using stata but the stata’s arfima module does not allow for the use of dummies accounting for the presence of breaks, which are crucial in my sample)
JMMB
experience_1900-2014_predictions 2100.WF1
(24.59 KiB) Downloaded 326 times
trubador
Did you use forum search?
Re: predictions
Postby trubador » Wed Apr 06, 2016 4:40 am
You should have/generate out-of-sample values for each independent variable in your model (i.e. T and T46).
