I am trying to upload panel data into Eviews 8 and on the first two poped out windows it normally shows the values and recognizes that the values are numbers but when I press "next" all the variables suddenly desapear and only show NA. (I also tried it in the Evies 7 and it worked fine, I do not know why it does not in the version 8 but I need the v8 for some test that are not in v7)
Please find attached my excel file and the images of Eviews.
Thank you very much for your answer.
Data import problem
Data import problem
- im3.PNG (24.75 KiB) Viewed 2581 times
- im2.PNG (32.8 KiB) Viewed 2586 times
- Variables2.xlsx
- (107.05 KiB) Downloaded 263 times
Re: Data import problem
Worked fine for me - is your copy of EViews 8 up to date?
