i can't get my programs to run in quiet mode---i tried version 8 and version 9
i am running a loop with 10,000 iterations requiring regressions and tables...etc----i don't want all the updates flashing on the screen
it takes forever
what am I doing wrong
thanks
Russ
i can't get my programs to run in quiet mode..
russellrobins
Re: i can't get my programs to run in quiet mode..
Hard to know what you're doing wrong without knowing what you're doing.
Perhaps you could post the workfile/program and describe how you're making it run quiet.
russellrobins
here is the program......i run the program from the Dialog box
thanks for the help
smpl @first @last
mode quiet
vector (10000) chow_values
rndseed 1
scalar i
FOR i = 1 TO 100
delete eq2 mytab
'series y_stable = 2 + 1.2*market + .8*hml -.5*smb + 2*nrnd
series y_stable2 = 2 + 1.2*market + .8*hml -.5*smb + 2*nrnd
'equation eq1.ls y_stable c market hml smb
equation eq2.ls y_stable2 c market hml smb
eq2.chow 100
freeze(mytab) eq2.chow 100
chow_values(i) = mytab(6,2)
thanks for the help
smpl @first @last
mode quiet
rndseed 1
scalar i
FOR i = 1 TO 100
delete eq2 mytab
eq2.chow 100
Remove the line:
eq2.chow 100
russellrobins
perfect, that worked
thanks
but why would anything show up, if I am running in quiet mode? Just curious
thanks
The command:
has an implicit show in front of it. Show overrides quiet.
eq2.chow 100
russellrobins
very cool
thanks
thanks
russellrobins
is there anyway of knowing what has the implicit show?
Not really. Generally anything that only displays results (like the Chow test) will have a show. There is absolutely no reason to perform the Chow test without a freeze statement unless you wanted to see the results, so if you do perform a Chow test without a freeze, EViews will show the results.
