ROC curve
Gulgun
Re: ROC curve
Postby Gulgun » Fri May 22, 2015 2:50 pm
Can we use the same codings also in eviews 8?
Re: ROC curve
Postby EViews Gareth » Fri May 22, 2015 2:51 pm
Yes., that code was written for EViews 8.
WerMaximus
Re: ROC curve
Postby WerMaximus » Thu Jun 04, 2015 12:28 am
The following assumes that the ordinary and tie-adjusted values are the same.
!n1 = 21 !n2 = 11 !unorm = 3.531162 !mu = !n1*!n2/2 !sigma = sqr(!n1*!n2*(!n1+!n2+1)/12) !u = !unorm*!sigma + !mu delete(noerr) rocarea scalar rocarea = !u/(!n1*!n2)
Hi Gareth or anyone who might know the answer,
I computed the AUC the way you described. When I run the regression with only one variable, I get different results for ordinary and tie-adjusted Wilcoxon/Mann-Whitney statistic. In those cases, what am I supposed to do? Can I just choose the ordinary one or is the test unusable for that? I am using Eviews 7.1
Best regards and many thanks in advance.
mikela
Re: ROC curve
Postby mikela » Fri Nov 06, 2015 7:37 am
is it possible to automate step 2. Ie, execute the test for equality by classification in the program and saving the test results rather than writing it down by hand?
I can't find the command to run the test.
Many thanks,
Mikela
Re: ROC curve
Postby EViews Glenn » Fri Nov 06, 2015 8:06 am
diggetybo
Re: ROC curve
Postby diggetybo » Thu Mar 24, 2016 10:16 am
I tried the above code (both eviews 8 and 7 versions) in Eviews 9 and it threw an error to the effect '65 is not a valid index of _____.'
So it seems to have issued too many elements to the vector or matrix, because my data set only contains 64 observations. I don't know what it's really doing though, just trying to be helpful.
I'm not sure how high this is on the priority list, but having a roc program would be really useful. I'm hoping this is revisited.
I dont know why my post is showing up here, please refer to my target thread:
http://forums.eviews.com/viewtopic.php?f=4&t=10614
diggetybo
Re: ROC curve
Postby diggetybo » Sat Jul 09, 2016 5:11 am
Months later,
It dawns on me that its actually the same thread, just the latest page. I didn't notice it had multiple pages and I was confused for a while. So disregard the comment on whether the thread was right or not. That was my bad.
Nonetheless, I still have that same error for this ROC curve program. Can someone walk through trouble shooting that with me, or advise me on what else I can consider using given that I'm running Eviews 9?
Thank you
diggetybo
Re: ROC curve
Postby diggetybo » Sat Jul 30, 2016 1:29 am
After more experimenting, I got the program to complete. Although it produced a graph that was not correct (my false positive rate x axis went from 0 to 2.5) I'm not sure why it doesn't span simply 0 to 1.
The issue before was the !i and !j were increasing beyond the rows of my matrix. I simply added an if statement to make sure they were less than the number of rows before proceeding with the !i = !i+1. I then added an else exitloop.
It appears these changes weren't needed for earlier versions of Eviews, but when I tried it with Eviews 9, it would not work. This slightly modified program will at least produce a graph, but there are some more bugs to be worked out. Can someone spot the remaining problems with the code? I have neared my wits end with it, but I'm not giving up. Have a look:
%dep = "inlf" %eq = "eq01" ' find valid observations {%eq}.makeresid _xxe ' get number of 0 and 1 smpl if _xxe<>na and {%dep} = 0 !n0 = @obs({%dep}) smpl if _xxe<>na and {%dep} = 1 !n1 = @obs({%dep}) ' get fittted values smpl if _xxe<>na {%eq}.forecast _xxyf group _xxa {%dep} _xxyf stom(_xxa, _xxb) stom(_xxyf, _xxprob) ' sort in descending order so we have threshold of infinity which is "off" vector _xxpranks = @ranks(_xxprob, "d", "i") matrix _xxsdata = @capplyranks(_xxb, _xxpranks) ' get unique fitted values !nunique = 1 for !i=2 to @rows(_xxsdata) if _xxsdata(!i, 2) < _xxsdata(!i-1, 2) then !nunique = !nunique+1 endif next !nunique=!nunique+2 ' create output ROC matrix matrix(!nunique, 4) _xxroc ' we start at threshold of infinity which is "off" !ntype1 = 0 ' number of correct 1 predictions !ntype0 = !n0 ' number of correct 0 predictions !j = 1 !i = 1 !n = @rows(_xxsdata) _xxroc(1, 1) = 1 - (!ntype0 / !n0) ' 1 - specificity _xxroc(1, 2) = !ntype1 / !n1 ' sensitivity _xxroc(1, 3) = 0 _xxroc(1, 4) = 0 while !j <= !nunique !target = _xxsdata(!i, 2) !val = !target scalar val_1 = !val while !val = !target !response = _xxsdata(!i, 1) if (!response = 0) then !ntype0 = !ntype0 - 1 endif if (!response = 1) then !ntype1 = !ntype1 + 1 endif if !i < !n then !i = !i+1 else exitloop endif wend _xxroc(!j+1, 1) = 1 - (!ntype0 / !n0) _xxroc(!j+1, 2) = !ntype1 / !n1 _xxroc(!j+1, 3) = !j / !nunique _xxroc(!j+1, 4) = !j / !nunique if !j < !n-1 then !j = !j + 1 else exitloop endif wend _xxroc(!j+1, 1) = 1 - (!ntype0 / !n0) _xxroc(!j+1, 2) = !ntype1 / !n1 delete(noerr) roc_graph freeze(roc_graph) _xxroc.xypair roc_graph.options linepat -legend size(4,4) roc_graph.setelem(1) linewidth(1.15) roc_graph.setelem(2) linepattern(8) %title = "ROC graph for" %title = %title + " " + @upper(%eq) roc_graph.addtext(t, font("Ariel", 12)) %title roc_graph.addtext(l) "True Positive Rate" roc_graph.addtext(b) "False Positive Rate" show roc_graph delete _xx*
tho_mi
Re: ROC curve
Postby tho_mi » Tue Mar 21, 2017 1:05 pm
This might be a bit late, but I also ran into problems using the code (even though it worked perfectly fine using another sample). After experimenting for about two hours I found out that the problems was the last row of "_XXSDATA". Both entries were zero and in the code there is the while-loop with the condition "!val = !target".
In theory !i should never go beyond the last row of "_XXSDATA", but since "!val" is set to 0 in case !i goes beyond the last row, it stays in the loop and then an error occured. Setting "!val" to -1 in this case solved the problem.
I'm not sure what your problem was. Did you manage to solve it?
