Internal Error 500
tslay
Internal Error 500
Postby tslay » Wed Sep 30, 2009 1:10 am
I'm trying to run a Blanchard-Quah-type VAR decomposition using Proc->Estimate Structural Factorization. But I need both Short-Run and Long-Run restrictions on the VAR estimation. However, when I do so, it gives me an error "Internal Error 500". I'm just wondering if this error number corresponds to an error in my specification of the model and/or the restrictions, or if eViews 6 (Enterprise Edition Jun 3 2008 build) is not able to handle having both Short-Run and Long-Run restrictions at the same time.
Thanks in advance!
Re: Internal Error 500
Postby EViews Gareth » Wed Sep 30, 2009 8:06 am
Internal Error 500 is something that should never happen, and usually indicates a bug in EViews. Would it be possible for you to send us your workfile, and instructions on exactly what you did to get that error to occur?
tslay
Postby tslay » Wed Sep 30, 2009 5:58 pm
I've attached my workfile (impst_realgdpc). What I did was select DLIND and DLI_P and created a VAR (1 lag only and constant) with them. Then I selected Proc->Estimate Structural Factorization and typed in the following restrictions:
@e1 = C(1)*@u1 + C(2)*@u2
@e2 = -C(1)*@u1+C(1)*@u2
@lr1(@u2)=0
impst_realgdpc.wf1
Workfile
(64.81 KiB) Downloaded 276 times
Postby EViews Gareth » Wed Sep 30, 2009 6:28 pm
Ok, that's not really a bug other than EViews isn't giving a proper error message. The problem is because you've mixed a long-run specification with a short-run one, which you cannot do. I'll see if we can get the error message changed to something better than the current one.
