Dear all,
I want to create a workfile with frequency argument, and import excel data.
When I create a workfile by using the following code:
wfcreate test d5 2013-7-1 2014-8-31
I can obtain a workfile with frequency argument, just like picture one:
When I import excel data by using the following code:
wfopen d:\dpr.xls range="Sheet1!B2:C428" names=(purchase,redeem)
The frequency argument is disappeared, just like picture two:
How can I keep the frequency argument when I import excel data?
Thanks!
keep the frequency argument when importing data
Re: keep the frequency argument when importing data
EViews obtains the frequency information from the Excel file. If there is no frequency information in the Excel file, EViews won't be able to find it, so you'll need to use the pagestruct command to impose it.
Thank you very much :DEViews obtains the frequency information from the Excel file. If there is no frequency information in the Excel file, EViews won't be able to find it, so you'll need to use the pagestruct command to impose it.
