Least Squares Regression Using a System on a Group
kszynkar
Postby kszynkar » Wed Feb 17, 2016 3:52 am
Hi, perhaps a silly question, but how do I create a set (System I assume) of linear least square regressions on a group. CSer is a series, and CServGroup is a group. This line of code would get me an equation on on the series:
equation CServEqn.ls CSer CSer(-1)
What I'm trying to do is:
system CServSys.ls CServGroup CServGroup(-1)
So essentially a set of of the operation above. However, when I double-click the resulting system, I don't see anything in it. Is there a way to do this?
Re: Least Squares Regression Using a System on a Group
Postby EViews Glenn » Wed Feb 17, 2016 10:26 am
Is the latter supposed to be estimating a VAR(1)?
kszynkar
Postby kszynkar » Thu Feb 18, 2016 1:09 am
Yes
Postby EViews Glenn » Fri Feb 19, 2016 11:00 am
Why not use the built in VAR tools?
var var1.ls 1 1 CServEqn CServGroup
kszynkar
Postby kszynkar » Mon Feb 22, 2016 9:43 am
Apologies, I misunderstood VAR(1).
I'm not interested in capturing the cross terms in the regression (ie. getting a coefficient for the sensitivity of my first series in the group to the second), and the above was just to illustrate what I'm trying to do, but it won't only be an auto-regression, there will be other terms in the regression.
Postby EViews Glenn » Mon Feb 22, 2016 10:08 am
You'll have to add the specification for each of your equations explicitly (apart form the implied error)
system a a.add var1= c(1) + c(2)*var2 + c(3)*var1(-1) a.add var2 = c(4) + c(5)*var1(-1) + c(6)*x
etc.
Then
a.ls
There are some tools for creating common specifications to ease some of the editing burdens. See the documentation on the system object, and the makesystem command proc for a group.
kszynkar
Postby kszynkar » Thu Mar 03, 2016 9:57 am
Perfect. Thanks for the help.
