Multiple panels in one figure
stefanp
Postby stefanp » Fri Feb 19, 2016 7:36 am
Dear all,
I would like to open multiple panels in one figure in order to compare my results. For example, I end up with Graph A and Graph B. Obviously, I can select both items simultaneously and simply open them. That is exactly what I need. However, I do not know the corresponding command.
Re: Multiple panels in one figure
Postby EViews Glenn » Tue Feb 23, 2016 8:39 am
If I understand the question correctly, the command you want is documented here: http://www.eviews.com/help/helpintro.ht ... 23ww176482
I think you want
graph graph_name.merge graph1 graph2 [graph3 ...]
