String Loop on Existing String Variable
diggetybo
Postby diggetybo » Thu Feb 18, 2016 7:59 am
Hello again,
I have a question on the following code:
%labels = "height width length weight density" %labels_xys = %labels for %i height width length weight density %labels_xys = @replace(%labels_xys, %i, %i+"_x "+%i+"_y ") next
Can I somehow use a string loop on an existing string variable that I declared so I don't have to type them all one by one? In another scenario, suppose that the string variable is updated then because my string loop doesn't know, it will only loop through the strings I manually typed there originally.
I tried:
for %i %labels
But that didn't work.
Leave a line if you got an idea.
Thanks for reading
Re: String Loop on Existing String Variable
Postby EViews Gareth » Thu Feb 18, 2016 10:43 am
for %i {%labels}
diggetybo
Postby diggetybo » Thu Feb 18, 2016 10:58 am
easy as that, thank you!
