Cross Correlation Table
tchaithonov
Postby tchaithonov » Tue Sep 22, 2009 3:12 pm
Hey Everyone,
I am trying to get the lagged correlations out from the cross correlation results but I found out that I couldn't freeze it (from code). I did the following:
freeze(tab1) cross(12) var1 var2
and of course it complains that cross is not defined in freeze. Any ideas what I should do? Thanks.
Tchaithonov
Re: Cross Correlation Table
Postby EViews Gareth » Tue Sep 22, 2009 3:14 pm
group g var1 var2 freeze(tab1) g.cross(12)
tchaithonov
Postby tchaithonov » Wed Sep 23, 2009 8:58 am
Thanks Gareth. So, now I want only the values in the lagged column (should be starting from cell D8), how should I get it and somehow copy it to a new/existing table object? I know I read something about it in the forum but I just couldn't find it. Thanks.
Tchaithonov
Postby EViews Gareth » Wed Sep 23, 2009 8:59 am
You'll have to extract each cell one at a time (unless you're using the EViews 7 beta!).
tchaithonov
Postby tchaithonov » Wed Sep 23, 2009 11:03 am
are you referring to copyrange? Okay, let me try that out then. Thanks!
