Retrieving non-zero minimum value of matrix column
diggetybo
Postby diggetybo » Wed Feb 10, 2016 8:07 am
Hey there,
I'm having trouble retrieving the minimum of a matrix column, because it has to be non-zero. The @cmin command doesn't seem to work for this purpose, as to be expected, it retrieves the true min.
Is there anything that can I can bring to bear in this situation? I'd rather not resort to transforming the matrix to wipe the zeroes out, it would make everything else in my program really complicated.
[Edit] Even after transforming the zeroes to "NA", @cmin reads the minimum of the column as "NA". What to dooo....
Re: Retrieving non-zero minimum value of matrix column
Postby EViews Gareth » Wed Feb 10, 2016 9:24 am
Might be easiest just to write a loop and calculate the minimum manually.
diggetybo
Postby diggetybo » Wed Feb 10, 2016 9:37 am
yea, thanks for thinking it through with me. This is the best I could do:
(existing matrix called: m1)
vector v1 = @columnextract(m1,1) for !i = 1 to @rows(v1) if v1(!i) = 0 then v1 = v1.@droprows(!i) exitloop endif next scalar v1_min = @cmin(v1)
Postby EViews Gareth » Wed Feb 10, 2016 9:55 am
That'd work. It might be marginally faster to calculate the minimum by hand.
scalar min = m1(1,1) for !i=2 to @rows(v1) if m1(!i,1) < min and m1(!i,1) <> 0 then min = m1(!i,1) endif next
diggetybo
Postby diggetybo » Wed Feb 10, 2016 9:57 am
Oh that does cut down on things, good idea:) Last question! Let's say I save that as a variable
!min = @cmin(v1)
Is there anyway I can search the original matrix "m1" and return the row+column number for !min?
Postby EViews Gareth » Wed Feb 10, 2016 10:30 am
Only manually.
