I have a series called "wip" and a group called "x". Is it possible to do a regression using the set of series in x as independent variables and wip as the dependent variable?
Regression Using Group of Lagged Series
Re: Regression Using Group of Lagged Series
If I'm understanding the question correctly
equation eq1.ls whip c x
should do the trick. If you are doing this from the dialog, just enter the dependent WHIP, followed by the regressors (I've included the constant C).
Ah, indeed it does. I'm actually trying to do:
equation wt_eq_s.ls @pc(wip) @pc(x)
which doesn't work. Without the "@pc" function it works.
Unfortunately you can not use functions of groups. Only functions of original series.
You can write a simple program that will make a group containing the functions of the series:
Then use pcx as your regressor group.
group pcx
for !i=1 to x.@count
pcx.add @pc(x(!i))
that works. Thanks Eviews Gareth
