Fill a matrix with scalars
olsisthebest
Postby olsisthebest » Fri Jan 29, 2016 4:46 am
I have 100 scalars and I want to put them into a column vector.
How can I do it with a loop?
Thank you.
Re: Fill a matrix with scalars
Postby EViews Gareth » Fri Jan 29, 2016 9:08 am
for !i=1 to 100 v(!i) = s!i next
olsisthebest
Postby olsisthebest » Fri Jan 29, 2016 9:39 am
Thank you, but the scalars dont have an ordinal name.
Their name do not reflect any order. Is there any alternative?
Postby EViews Gareth » Fri Jan 29, 2016 9:43 am
Are there only those 100 scalars in the workfile, or are there other scalars too?
olsisthebest
Postby olsisthebest » Fri Jan 29, 2016 10:06 am
There are 300 scalars.
I want to fill 3 matrices with 3 different loops.
Why do you ask? If there was only 100 scalares the procedure will be different?
Thank you, Gareth.
Postby EViews Gareth » Fri Jan 29, 2016 10:41 am
Well if there is no naming pattern, how do you imagine EViews will know which ones to put where? The only way to do it is to manually assign if there is no logical pattern. Note you can use vector.fill to speed things up a little.
olsisthebest
Postby olsisthebest » Fri Jan 29, 2016 10:56 am
I was thinking in put the scalars name into a string and then loop over the string.
It is possible?
Postby EViews Gareth » Fri Jan 29, 2016 11:52 am
Sure, but easier just to use fill.
olsisthebest
Postby olsisthebest » Mon Feb 01, 2016 8:48 am
Thank you.
It is possible to use wild cards in vector.fill argument? The scalars begin with the same letters.
Postby EViews Gareth » Mon Feb 01, 2016 8:56 am
No.
