Pedroni FMOLS
odincer
Pedroni FMOLS
Postby odincer » Thu Jan 07, 2016 12:31 pm
When I estimate the same specification with FMOLS, RATS and EVIEWS give significantly different results (not only the magnitude of the coefficients but also the signs are different). Any input will be greatly appreciated.
Thanks,
Oz
Re: Pedroni FMOLS
Postby EViews Gareth » Thu Jan 07, 2016 1:35 pm
You will probably receive more feedback if you share the data/results
odincer
Re: Pedroni FMOLS
Postby odincer » Thu Jan 07, 2016 2:24 pm
The data that I am using are not publicly available and I am not allowed to share. I was just wondering if anybody had that problem before and a likely explanation.
Re: Pedroni FMOLS
Postby EViews Glenn » Fri Jan 08, 2016 12:34 pm
Are the methods used for estimating the non-parametric correction set to the same settings?
