Hi guys,
Rookie question - how do you set a regression coefficient to 1 in E-views?
Y = c(1)+ X
Would writing an equation in the above fashion ensure coefficient on X is implicitly set to 1?
Any other ideas?
Thanks. Appreciate it a lot.
Re: regression coefficient
Good question. What happened when you tried it?
That should work. An equivalent is to use the by-list formulation
but in this case, your descriptives will be on the composite variable, not on Y (which may not be what you want).
y-x cWho is online
