Access Table Data in Formula?
kcaron
Postby kcaron » Fri Dec 04, 2015 9:02 am
Is it possible to write a formula that references a cell in a saved EViews table?
If so, what is the method for doing so?
Thanks!
-K
Re: Access Table Data in Formula?
Postby EViews Gareth » Fri Dec 04, 2015 9:21 am
Define what you mean by formula.
kcaron
Postby kcaron » Fri Dec 04, 2015 9:58 am
Formula for a line... Where my independent variables are stored in a table and the coefficients are drawn from a regression equation.
dependent = regression.c(1) * independent + regression.c(2)
Where...
regression.C(1) is the coefficient and regression.C(2) is the constant from a saved regression equation (called "regression"), and
independent is some number that I make up and store in a table. (Let's say the table is called "mytable")
Thx!
K
Postby EViews Gareth » Fri Dec 04, 2015 10:01 am
Sorry, what do you mean by "line"?
Are you trying to create a formula object?
kcaron
Postby kcaron » Fri Dec 04, 2015 10:04 am
yes. sorry.
Postby EViews Gareth » Fri Dec 04, 2015 10:06 am
You can refer to the table cell just from mytable(3,1). But the formula will not dynamically update every time the table updates. Formula objects only update when series do.
kcaron
Postby kcaron » Fri Dec 04, 2015 10:37 am
Hmmmm...
I'll play around with it. Thank you!
-K
