Hello:
I have created a minimum working example in EViews 9:
wf m 1990 2020
genr x = @nrnd
equation eq01.arch x c ar(1)
Upon execution, EViews whites out and shuts down. For actual data series, my ARCH estimation works with no AR terms. Also, the same output as above results in no error for a coworker using EViews 9. I am working on a 64-bit Windows 7 Professional. The EViews build is October 22, 2015, and this build is the only factor I expect that is different between my colleagues and my situation which could therefore explain this difference in results. Do you have any suggestions about how to address this break?
Thank you
EViews AR(1) ARCH Crash
Re: EViews AR(1) ARCH Crash
First thing, try updating to the current build.
Please update your copy to the latest version.
supplysideswiss
Ok I will do that and let you know when my company processes this request, in the next few business days.
supplysideswiss
Updating to the newest version worked, I don't have this problem anymore. Thanks!
Great, sorry for the inconvenience.
