Basic Rolling Regression
Re: Basic Rolling Regression
Each subsamples coefficients are stored in coefmat. You'll have to change the program to store the standard errors in the same way.
Thanks Gareth! How to store subsamples R-squared in Eviews?Each subsamples coefficients are stored in coefmat. You'll have to change the program to store the standard errors in the same way.
Dear all,
I am new to use Eviews and I have been trying to replicated the basic rolling regression. After following all the steps mentioned in the first post, I find the message "!step not defined" when I reach to the following point:
!nrolls = @round((!length-!window)/!step)
Although I do define !step=40 as done in the first post.
Sorry for naivety, please can anybody help me with this? Why do I get such message? I have tried many times.
Many thanks,
Mukhtar
Many thanks,
Mukhtar
Hard to say without seeing what you've done.
For anyone still looking for a code that does a 1-period ahead recursive regression forecast (expanding window), I put together something from posts all over this forum. Most of the credits for these codes go to Esther and Gareth.
Try the code below. Note that I left out the coefficient matrix.
I have no real programming experience, so keep in mind that the code might not work 100% correctly. Any improvements are appreciated.
'create some data
create u 100
series y=nrnd
series x1=nrnd
series x2=nrnd
series z=nrnd
'run rolling regression
' set window size
!window = 20
' set step size
!step = 1
' get size of workfile
!length = @obsrange
' declare equation for estimation
equation eq1
'calculate number of rolls
!nrolls = @floor((!length-!window)/!step)
'series to store forecast estimates
series fcast
'*EDITED: catching start and end points
%start = "@first" '@otod(@ifirst(ser))
%end = "@last" '@otod(@ilast(ser))
'variable keeping track of how many rolls we've done
!j=0
' move sample !step obs at a time
for !i = 1 to !length-!window+1-!step step !step
!j=!j+1
' set sample for estimation period
%first = @otod(@dtoo(%start))
%last = @otod(@dtoo(%start)+!i+!window-2)
smpl {%first} {%last}
' estimate equation - where the equation is y =c(1) + c(2)*x1 +c(3)*x2
eq1.ls y c x1 x2
' 1-period-ahead forecast
%1pers = @otod(@dtoo(%start)+!i+!window-1) 'start point
%1pere = @otod(@dtoo(%start)+!i+!window-1) 'end point
'*EDITED
if @dtoo(%end) < @dtoo(%1pere) then 'check whether the forecast end point is greater than the workfile end point
exitloop
endif
' set smpl for forecasting period
smpl {%1pers} {%1pere}
' forecast with command *forecast* (see also *fit*)
eq1.forecast(f=na) yf
' set sampl to obtain the 4th period observation
smpl {%1pere} {%1pere}
' store forecasts
fcast = yf
smpl @all
show fcast.line
d(noerr) yfRe: Basic Rolling Regression
Many thanks you for your help Gareth and Esther.
I am using EViews 7.2 and have been able to do a h-period ahead recursive regression forecast thanks to this post. However, I would also like to add exogenous variables to my model, and these need to be forecasted for each step with an ARMA structure (say AR(1)). I am struggling with the organization of the code, could anyone help me ?
I don't understand what you're trying to do
Hallo everyone!
I am new in the forum and I am not familiar with the EVIEWS programming language, so I would really appreciate some help!!
My forecasting equation is: Exchange rate=c+c(1)(log_cpi_uk-log_cpi_us)
I want to run the out-of sample forecasting test with recursive window forecasting scheme. I use some commands seen in the forum such as:
' set window size
!window = 576
' set step size
!step = 90
!length = @obsrange
equation eq1
'matrix to store coefficient estimates
matrix(2,!nrolls) coefmat ' where 2 is the number of coefficients
series fcast
%start ="@first" ' @otod(@ifirst(ser))
%end="%last" '@otod(@ilast(ser))
!j=0
!j=!j+1
%first = @otod(@dtoo(%start)+!i-1)
' estimate equation - where the equation is y=c(1) + c(2)*x1
eq1.ls log_spot c (log_ipi_uk-log_ipi_us)
'store coefficients
colplace(coefmat,eq1.@coefs,!j)
%1pere = @otod(@dtoo(%start)+!i+!window) 'end point
'*EDITED
exitloop
endif
' store forecasts
fcast = yf
smpl @all
show coefmat
show fcast.line
d(noerr) yf
But when I run the program I get the message "Matrix or vector given non positive dimensions in the "Matrix (2,0) COEFMAT" .
' set window size
!window = 576
' set step size
!step = 90
!length = @obsrange
equation eq1
series fcast
!j=0
!j=!j+1
'store coefficients
'*EDITED
exitloop
endif
' store forecasts
fcast = yf
smpl @all
show coefmat
show fcast.line
d(noerr) yf
Looks like !length is the same as !window. i.e. your rolling size is the same size as the number of observations you have. Which makes no sense.
Thank you for your response. How can I deal with that? Which part of the programming shall I change? To make my self clear I will give you more details regarding my project: My sample consists of 576 have observations, starting from M1 1969 to M12 2013. The in-sample period is taken to be from the beginning to M12 1985 and the rest are the out-of-sample observations. I want to produce me first forecast on M1 1975 and then recursively estimate next coefficients. How do I change my code in order to adjust on the above?
Thank you very much for your time!
Do you want a rolling regression or an expanding one?
A recursive regression (expanding)
Could you explain what that means?
That I use a period of time to produce my first coefficient and then I add an observation and re-estimate my model..I do these iterations until the end of the sample period.
You'll need to completely re-write the sample parts then, since you're not doing rolling regression.
Return to “Program Repository”
