PANEL DATA
Re: PANEL DATA
Postby startz » Wed Nov 11, 2015 9:15 am
What value would you like y1 to take if h1 is not 1?
COM446
Re: PANEL DATA
Postby COM446 » Wed Nov 11, 2015 10:44 am
I want to create 3 continuous series: y1 contains only x1 (when h1=1), y2 contains only x1 (when h1=2)...the sample size for each series will be 1/3 of whole sample
Re: PANEL DATA
Postby startz » Wed Nov 11, 2015 10:51 am
You can't run a regression, much less ARCH, with missing data. Perhaps you want x1=0 when h1 is 2 or 3?
COM446
Re: PANEL DATA
Postby COM446 » Wed Nov 11, 2015 11:14 am
Ok, I will generate the new data series outside of eviews. Thanks a lot.
Re: PANEL DATA
Postby startz » Wed Nov 11, 2015 11:17 am
This has nothing to do with where you generate the series. If you generate them outside of EViews and bring them in you are going to get the exact same error message if you have missing values.
