hello
is there any command to create series with binary distribution?
something like @rnd for normal distribution
thanks in advance!
hirastikanah
Re: any command to create series with binary distribution?
For a binary, just use @rnd (note that @rnd is a random uniform, not normal) to create a dummy using the desired success probability, as in
will generate a (0, 1) variable with success probability p.
series binary = @rnd > (1-p)
hirastikanah
For a binary, just use @rnd (note that @rnd is a random uniform, not normal) to create a dummy using the desired success probability, as inwill generate a (0, 1) variable with success probability p.Code: Select all
Great!
thanks a lot :)
