Selection of optimal lag length in ARDL Bound test
Hirajanjua
Postby Hirajanjua » Fri Jun 19, 2015 2:21 am
Hello to all,
Currently i am working on ARDL bound test for my project..but i am facing few problems it would be great if you help me out.
Firstly i have six variables (including my depended variable) with 43 number of annually observations and having combination of I(0) and I(1).
one of basic step what i get while studying about ARDL bound test is to use optimal lag length while construction your model, my question is how i select optimal lag length there must be some method or criteria by following it one select optimal lag length.
Kindly help me out..Thank you in advance...
djboy
Re: Selection of optimal lag length in ARDL Bound test
Postby djboy » Sat Sep 19, 2015 4:26 am
hi
this is my problem.too
siq
Postby siq » Mon Nov 02, 2015 4:18 pm
u.the method i know about optimal lag is below: may be it helps u
optimal lag length can be obtain in eviews..open quick menu ---> estimate var ---> write two of your variables in endogenous variable box(or all variables ) , writ constant name in exogenous variable box give lag interval like 1 2 . press ok
view menu-->lag structure --> lag length criteria --> enter lag value till 6 (i m not sure about this, according to your work ), select the lag which has maximmum stars like below ( lag 1 has max stars so this is the ptimal lag for the your variables)
Lag LogL LR FPE AIC SC HQ
0 -43.67185 NA 0.040479 2.468748 2 .555825 2.499447
1 101.1663 266.1891* 2.00e-05* -5.144126* -4.882896* -5.052030*
2 102.3907 2.117822 2.33e-05 -4.994092 -4.558708 -4.840599
3 103.3477 1.551911 2.76e-05 -4.829606 -4.220069 -4.614716
