I have seen other posts here about writing a program for estimating a particular order of ARMA model. Yet I'm interested in writing one allowing any order, i.e. the user may insert any order for AR and MA.
Let y be the dependent variable, I noticed that one may program the residuals as y - mu(1) - @nan( mu(1)+phi(1)*y(-1)+phi(2)*y(-2)+theta(1)*res(-1)+theta(2)*res(-2), 0) for an ARMA(2,2) model. Yet it doesn't allow a more general case.
I've tried something like this:
Let !AR be the AR order to be entered and phi be the coefficients and mle be the object for the MLE. So the AR part becomes,
series ARs=0
for !i=1 to !AR
ARs=ARs+phi(!i)*y(!i)
NEXT
mle.append ARs=ARs
Well, it doesn't work. Any thoughts?
My ultimate goal is to build a univariate GARCH model allowing other types of underlying distributions.
Estimating an ARMA model of any order in general
Re: Estimating an ARMA model of any order in general
I'm not sure what you're trying to do. Why not just use the built in equation object?
Thanks for your reply.
I'am trying to make a program that allows me to estimate an ARMA model (later develop to GARCH) of any order. For instance, minimising "y - mu(1) -alpha(1)*y(-1) -alpha(2)*y(-2)" refers to an AR(2) model yet what if I want to estimate, say, an AR(10) model? I'm hoping to write a program in which I don't have to type "alpha(-1)*y(-1) , alpha(-2)*y(-1) , .... alpha(-n)*y(-n)".
The reason I'm not using the built-in one is that I'm trying to estimate some GARCH models whose underlying residuals are not normal, t or GED distrbuted. I'm also using R at the same time. While R is very flexible that I can easily write a function, calculation takes much longer time.
ok, and how are you estimating this model?
This is what I've done so far. I just started EViews programming a few days ago.
As you can see, I'm trying to make the order of the model flexible. Yet the log-likelihood part requires typing in the exact equation. It is a GARCH model but with the Johnson SU as the underlying distribution. Rather than directly using the Johnson SU PDF in the likelihood function, a transformation is used so the Gaussian PDF can be used. Unfortunately, errors persist due to the very restrictive arc cosh function (not a built-in function in EView so I used the exact form instead. That is, arccosh(x)=log(x+sqr(x+1)*sqr(x-1))).
genr y=ftse_dr
'Set model order
!AR=2
!MA=5
!ARCH=2
!GARCH=3
'Reduce the sample to the most recent 5000 observations
smpl @all
if @obs(y)>5000 then
!N1=@obs(y)-4999
!N2=@obs(y)
smpl !N1 !N2
endif
'Declare coefficients
coef(1) mu
coef(!AR) phi
coef(!MA) theta
coef(1) omega
coef(!ARCH) alpha
coef(!GARCH) beta
coef(1) lamda
coef(1) delta
'Produce random initial values
mu(1) =@runif( -2,2)
for !i=1 to !AR
phi(!i)=@runif(-2,2)
NEXT
for !i=1 to !MA
theta(!i)=@runif(-2,2)
NEXT
omega(1) =@runif(0,1)
for !i=1 to !ARCH
alpha(!i)=@runif(0,1)
NEXT
for !i=1 to !GARCH
beta(!i)=@runif(0,1)
NEXT
lamda(1)=@runif(0,0.3)
delta(1)=@runif(20,100)
'Set Pi
!PI=3.141592653589793238462643383279
'the likelihood function
logl jsu
jsu.append @logl loglike
jsu.append res = @nan(y - mu(1) -mu(1)-phi(1)*y(-1)-phi(2)*y(-2)-theta(1)*res(-1)-theta(2)*res(-2)-theta(3)*res(-3)-theta(4)*res(-4)-theta(5)*res(-5) ,0)
jsu.append sig2 = @nan(omega(1) + alpha(1) * ( res(-1) )^2 + alpha(2) * ( res(-2) )^2 + beta(1) * sig2(-1)+ beta(2) * sig2(-2)+ beta(3) * sig2(-3),omega(1))
jsu.append eps=res/sqr(sig2)
jsu.append w=exp(delta(1)^(-2))
jsu.append acosh=((2*sig2)/(lamda(1)^2*(w-1))-1)/w
jsu.append gamma=log(acosh+sqr(acosh+1)*sqr(acosh-1))*delta(1)/2
jsu.append k=sqr((2*sig2-lamda(1)^2*(w^2-1))/(2*(w-1)))
jsu.append asinh=(res-k)/lamda(1)
jsu.append z=gamma+delta(1)*log(asinh+sqr(asinh^2+1))
jsu.append loglike = log(@dnorm(z) )- log(sig2)/2
jsu.ml(showopts)
'Saving info criteria
scalar aic = bedvar.@aic
scalar bic = bedvar.@schwarz
scalar hqc = bedvar.@hq
'Display result
show jsu.output
genr y=ftse_dr
'Set model order
!AR=2
!MA=5
!ARCH=2
!GARCH=3
smpl @all
!N1=@obs(y)-4999
!N2=@obs(y)
smpl !N1 !N2
endif
coef(1) mu
coef(!AR) phi
coef(!MA) theta
coef(1) omega
coef(!ARCH) alpha
coef(!GARCH) beta
coef(1) lamda
coef(1) delta
for !i=1 to !AR
NEXT
for !i=1 to !MA
NEXT
for !i=1 to !ARCH
NEXT
for !i=1 to !GARCH
NEXT
'Set Pi
logl jsu
jsu.ml(showopts)
'Display result
show jsu.output
You'll have to build up a text string containing the terms you want, then substitute out that string inside the logl object with an append.
Something like:
Something like:
%arpart = ""
for !i=1 to !ar
%arpart = %arpart + " + phi(" + @str(!i) + ")*y(" + @str(!i)+")"
mle.append {%arpart}
