In regard of my research I am working with EViews - 6 for the first time.
Can anybody help me with the following question 'how can I distangle a composite error term in EViews?'
Or can anybody give me directions where to find how to do it
Thanks in advance
C.S.
Composite error term
Re: Composite error term
What's a "composite error term?"
I need to estimate a translog production function.
A composite error term consists of statistical noise, vi (~iidN) and systematic time-varying departures,
The disturbance term ε = vi−ui
Now I need to distangle ε to estimate x-efficiency...
EViews makes it easy to model the total error term as ARMA, which gives a predictable part and a noise part, but I'm not at all sure if that's what you want.
As I am a first user of EViews, I need first to look up 'ARMA'
Now I can estimate the translog function. I obtain RESID
If i understand the theory good, I now need to distangle RESID into the two components.
Because I need to work further with vi
If ARMA is the technique, I need first to try this
Thanks I hope this will solve my problem
To get started, choose index in the help file and click on AR terms.
Favouredchild
Interpreting VEC estimates
I am new on Eviews 6 and I dont know what to make of the result I just got. What does the pasted copy below tell me about the relationship between the two variables. Urgent help need please.
Vector Error Correction Estimates
Date: 09/01/09 Time: 18:17
Sample (adjusted): 1972 2007
Included observations: 36 after adjustments
Standard errors in ( ) & t-statistics in [ ]
Cointegrating Eq: CointEq1
ENERGY_CON(-1) 1.000000
GDP(-1) -0.086484
(0.03186)
[-2.71438]
C -693.6977
Error Correction: D(ENERGY_CON) D(GDP)
CointEq1 -0.216473 -1.268542
(0.05616) (0.43699)
[-3.85438] [-2.90289]
C 2.739333 26.41963
(1.88657) (14.6791)
GDP(-1) -0.086484
(0.03186)
[-2.71438]
C -693.6977
(0.05616) (0.43699)
C 2.739333 26.41963
(1.88657) (14.6791)
Re: Interpreting VEC estimates
If you do a simple search in the forum, you'll find numerous explanations on similar cases like this one.I am new on Eviews 6 and I dont know what to make of the result I just got. What does the pasted copy below tell me about the relationship between the two variables. Urgent help need please.
