i have noticed that unlinking data or using @clear for frmls selectively eliminates all the entries; this was not the case previously (the macro i use for this proceedure is years old); what is so confusing is that there seems not to be a pattern when something will be erased or not;
to replicate the problem goto the export worksheet open e.g. all y_m_cbrate_us_* as group and look at all the data, run the command unlink * ; after that the entry y_m_cbrate_us_fcw will disappear; note, this is also the case when using @clear for each single entry if used in a macro; if you do it selectively - i.e. goto the individual series and unlink it manually by putting it back to values, it will keep the values in the series;
best
Michael
unlinking/cleaning data eliminates entries
SMSQ Michael
Re: unlinking/cleaning data eliminates entries
Sorry, but I'm not sure what you meant by "export worksheet". Was it one of our example files? If so, what was the name of the file?
Otherwise, I can't seem to recreate your issue.
SMSQ Michael
sorry, just noticed that the file upload did not work; the file is too large; is it possible to send it in another way?
email to support@eviews.com. If too large for email, try something like https://www.wetransfer.com/
SMSQ Michael
ive sent you the file via mail - can you let me know if your have received it?
best
Michael
best
Michael
ok we have a fix ready -- we're building a patch today so you should be able to update your copy of EViews 9 in a few hours or so...
