From a group with 7 time series variabels (called "bidrag") I get a nice graph with bars for the 6 first variables, and a line for the 7th using:
bidrag.mixed bar(1,2,3,4,5,6) line(7)
However, typically, some of the 6 components in "bar" are negative in a given time period, meaning that
bidrag.mixed stackedbar(1,2,3,4,5,6) line(7)
does not make sense, since the stacking does not sort between positive and negative values. What I am fishing for here is graph where (in each time period) "positives" are stacked in a bar above the zero line, and negatives are stacked in a bar below!
Have I overlooked an option, perhaps?
stackedbar with negatives
Re: stackedbar with negatives
You will have to create a graph object first and then use the stackposneg option
group mygroup x1 x2 x3
freeze(graph01) mygroup.mixed stackedbar(1,2) line(3)
graph01.options stackposnegWho is online
