Structural Break Tests
jhh
Postby jhh » Sun Sep 27, 2015 11:07 pm
My data set contains 55 data points. I want to run a structural break tests. I am using eviews 8. what are the steps that i need to follow to carry out the Bai and Perron test?
thank you for your help.
Re: Structural Break Tests
Postby EViews Gareth » Mon Sep 28, 2015 7:53 am
Estimate an equation using Quick->Estimate, then once it is estimated, click on View->Structural Diagnostics->Multiple Breakpoint test.
jhh
Postby jhh » Wed Sep 30, 2015 1:49 am
i am using an univariate Unobserved components model on a single time series. i want to include a dummy variable to capture the break date. so i am confused as to which equation should i estimate?
once again thank you.
