Alternating GMM estimators
arturobandini
Postby arturobandini » Mon Aug 31, 2009 1:31 pm
Hi everybody,
I'm running a self-written procedure that has among others two equations that I estimate with GMM. I would like to alternate between the two-step, iterative and continuously-updating GMM estimators, as well as with different bandwidth specifications of the Newey-West estimator in order to assess possible discrepancies in the estimations.
For instance, to estimate the two-step GMM with fix bandidth=12 according to the instructions of the EViews Command Reference, I write:
eq.gmm(c,b=12) y c x1 x2 x3
However, it doesn't change anything to the results the output still says "Simultaneous weighting matrix & coefficient iteration" and "Kernel: Bartlett, Bandwidth: Fixed (3), No prewhitening".
Does anybody see what could possibly be wrong?
Thx so much in advance!
Art.
Re: Alternating GMM estimators
Postby EViews Gareth » Mon Aug 31, 2009 3:25 pm
Nothing wrong with your syntax that I can see. You should post your program/workfile.
arturobandini
Postby arturobandini » Mon Aug 31, 2009 3:41 pm
Thx for the quick reply!
So here's the programm and the workfile. Just ask if there's anything unclear! The two gmm equations I mentionned are about halfway down in the programm...
Best, Art.
Workfile GMM.wf1
The workfile
(322.27 KiB) Downloaded 357 times
Programm GMM.prg
The estimation procedure
(6.12 KiB) Downloaded 434 times
Postby EViews Gareth » Mon Aug 31, 2009 4:21 pm
Nowhere in your program do I see a GMM command that sets the bandwidth.
In fact I can't find any GMM commands that have any options at all....
arturobandini
Postby arturobandini » Mon Aug 31, 2009 4:32 pm
Thx for the reply. You're correct.
Here's the right version with the two gmm equations with option for two-step estimator and bandwidth=12 that do not seem to work...
Thx a lot, Art.
programm gmm 2.prg
(6.2 KiB) Downloaded 433 times
Postby EViews Gareth » Mon Aug 31, 2009 4:59 pm
Every time you estimate an equation via GMM with options, you then immediately re-estimate it by GMM with no options.
At a guess where you have:
equation acils1.gmm libor3m c cpi(+k) gap fxgap @ cpi(-1 to -6, -9, -12) gap(-1 to -6, -9, -12) fxgap(-1 to -6, -9, -12) freeze(mode=overwrite, tableci1) acils1.gmm
You probably want:
equation acils1 freeze(mode=overwrite, tableci1) acils1.gmm libor3m c cpi(+k) gap fxgap @ cpi(-1 to -6, -9, -12) gap(-1 to -6, -9, -12) fxgap(-1 to -6, -9, -12)
or something similar
arturobandini
Postby arturobandini » Mon Aug 31, 2009 5:18 pm
Thx for the reply again! This is indeed where the problem was... I thought that it was not necessary to restate your options when you just want to store the estimates into the table. Good to know!
By the way, a suggestion of mine regarding the Commands Reference might be to link clearly the different options to the different gmm estimators as they are exposed in all textbooks.
My guess is: "o"= two-step gmm (hansen 1982), "s"= iterated gmm (Ferson and Foersterb, 1994), "i"=continously-updating gmm. But then I don't know what I should associate with "c"...
Another aspect to clarify would be wether those different options change the first-step estimate of the weighting matrix. The Eviews Guide II says it is the consistent TSLS estimator but I was not sure if it was indeed the case for all these options (another option might be the identity matrix...).
Anyway, thank you very much!
Art.
Postby EViews Gareth » Mon Aug 31, 2009 5:40 pm
