"Internal Error 500 500" when Forecasting
sarah_ec
Postby sarah_ec » Thu Aug 27, 2015 2:58 am
Hi all,
I tried to run an ex-post in sample dynamic forecast of my OLS equation, but each time I receive the error "Internal Error 500 500". I tried to google the problem but found no answer. Anyone an idea what it could be about?
Thanks to anyone who takes the time to read this!
sarah_ec
Re: "Internal Error 500 500" when Forecasting
Postby sarah_ec » Thu Aug 27, 2015 3:24 am
I just found out that Eviews actually has created the forecast, although showing me the error. I conducted the forecast again and still got the error, but the forecast was again created. I just hope that the numbers are correct...
Postby EViews Gareth » Thu Aug 27, 2015 6:02 am
What version and build date of EViews? (Help->About EViews)
sarah_ec
Postby sarah_ec » Thu Aug 27, 2015 7:48 am
Sorry for not mentioning, it is Eviews 9.
Postby EViews Gareth » Thu Aug 27, 2015 7:50 am
What's the build date?
sarah_ec
Postby sarah_ec » Thu Aug 27, 2015 8:56 am
May 29 2015
Postby EViews Gareth » Thu Aug 27, 2015 9:11 am
Update to the latest version.
sm959
Postby sm959 » Tue Jan 19, 2016 10:59 am
I too get an "Internal Error 500 500" when forecasting in Eviews 9 (build 7 Jan 2016).
I estimate a least squares panel with cross-section and period fixed effects. When trying to forecast, the "Internal Error 500 500" pops up, although the forecast is produced in the background. Interestingly, the error goes away when I untick the box for standard errors in the forecast specification. Equally, removing the fixed effects seems to resolve the error. Does this imply that I cannot use the normal standard errors when forecasting a fixed effects model?
As the loop in my programme breaks down due to the error, I'd be very grateful for suggestions as to how to resolve it.
Many thanks in advance,
Sam
Postby EViews Gareth » Tue Jan 19, 2016 11:04 am
Could you provide the workfile/program?
sm959
Postby sm959 » Wed Jan 20, 2016 1:19 am
Thanks for your quick reply. Please find a schematic representation of the workfile attached. Running a forecast on eq01 produces the error.
workfile_error500.wf1
(15.1 KiB) Downloaded 239 times
Postby EViews Gareth » Wed Jan 20, 2016 9:06 am
I believe the error is caused by the lack of a constant in your equation's specification (note that EViews puts one in automatically, but that causes issues later on). We'll fix the bug, but in the mean time you can work around it by adding a constant to your specification.
sm959
Postby sm959 » Fri Jan 22, 2016 9:30 am
Great, thanks, that works!
