Several Questions Regarding Serial Correlation
Dickson
Postby Dickson » Sun Jun 07, 2015 3:23 am
Hello
First, I would like to ask if there is any way to reduce serial correlation in my residuals. I am applying the DOLS methodology and by manipulating the leads and lags, I achieve the correlogram that is at the end of this post.
The second question is, whether that much correlation as the one I have is actually a problem. I have heard that small correlation can be neglected, however, I am not exactly sure how much correlation can be regarded as "small".
Lastly, if I do have correlation, can applying HAC (Newey-West) compensate for this?
lauritam
Re: Several Questions Regarding Serial Correlation
Postby lauritam » Sat Aug 22, 2015 12:35 am
Hi there,
Just asking if you could fix your correlation problem? I am using DOLS for a panel, and I have the same issue but I haven't found any luck for dealing with it. I was told about the cochrane-orcutt procedure. You might want to check it out!
Good luck
