Hi guys,
I conduct Bayesian VAR model to make conditional forecast. However, VAR Residual Portmanteau Tests for Autocorrelations shows that the residuals is correlated.
I tried to add more variables and change the lag order, but it doesn't work.
Can you please tell me how to overcome this problem?
Many thanks in advance.
Residual autocorrelation in Bayesian VAR
PoachedWonk
Re: Residual autocorrelation in Bayesian VAR
I am having a similar issue, It seems that by extending the lags, autocorrelation becomes more of an issue, rather than less...
Can I use the Portmanteau / AC LM test on BVARs? Or am I doing something wrong??
PoachedWonk
Hi the resolution to this is to change the priors, if lambda 1 is too low, then we assume the prior values are more or less correct, which restricts the convergence of the model and leads to autocorrelation.
