command which gives out p-values?
Lama
Postby Lama » Fri Nov 14, 2008 9:51 am
I want to do a stepwise "regression" but not with an OLS but with an ordered probit problem. As far as I can see, the stepwise regression implemented in EVIEWS is for linear regressions exclusively?
Is there a command which gives out the p-values (which I want to use as stop criterion) or is it necessary to compute them with the values of the t-statistics?
Re: command which gives out p-values?
Postby EViews Gareth » Fri Nov 14, 2008 10:02 am
You are correct that the in-built stepwise routine only handles linear models.
You are also correct that the best way to get the p-values is to compute them using the t-statistics.
You should note though, that if you are only interested in the p-values as selection criteria for the stepwise routine, you don't really need to calculate the p-values at all, simply convert the p-value criteria into a t-statistic criteria, and then use the t-stats themselves.
