FGLS Question
diggetybo
FGLS Question
Postby diggetybo » Tue Jun 30, 2015 6:40 pm
My textbook has a question I've been trying to crack for days. I can't match the books output results for using FGLS to quasi-difference as a correction for serial correlation in the errors. The regressors are assumed to be strictly exogenous.
I have at least reproduced the book's OLS output:
dependent variable: log(chnimp)
c=-17.80
log(chempi)=3.12
log(gas)=0.20
log(rtwex)=0.98
befile6=0.06
affile6=-0.03
afdec6=-0.57
R-squared = .305
From here I saved the residuals, then used them for the auxiliary regression of errors on the lag of errors. From here I saved the fitted values as an estimate of ro (autocorrelation). My FGLS weight in Eviews is: (1-(ro_hat^2))^.5
However my FGLS results are basically the same as OLS, the books PW results are markedly different:
c=-37.08
log(chempi)=2.94
log(gas)=1.05
log(rtwex)=1.13
befile6=-.02
affile6=-.03
afdec6=-.58
R-squared= .202
I attached the workfile, if anyone manages to match the book or catch a mistake.
barium.wf1
(43.69 KiB) Downloaded 406 times
Re: FGLS Question
Postby startz » Tue Jun 30, 2015 8:57 pm
Is your ro_hat a single number or a series of different numbers?
diggetybo
Re: FGLS Question
Postby diggetybo » Tue Jun 30, 2015 10:09 pm
I tried as a single entry in scalar form via the coefficient of u_hat on u_hat(-1), and I also tried as a series, neither way seems to match the book's answer. I've been looking at this for too long maybe, I can't seem to spot the problem heheh.
trubador
Did you use forum search?
Re: FGLS Question
Postby trubador » Wed Jul 01, 2015 4:40 am
PW is an iterative procedure, where you estimate rho until it converges. Your FGLS weight is just a fixed coefficient that PW uses to make a transformation of the initial observation. Unless you want to write a code for the procedure, you can use the following command:
equation pw.ls(arma=gls, optmethod=opg) log(chnimp) c log(chempi) log(gas) log(rtwex) befile6 affile6 afdec6 ar(1)
diggetybo
Re: FGLS Question
Postby diggetybo » Wed Jul 01, 2015 7:52 am
Yes, that did the trick! Thank you to you guys for helping me out. It's making a lot more sense now.
