How to Run unit root tests on part of a series?
jmccown
Postby jmccown » Sun Jun 21, 2015 12:42 pm
I am doing a monte carlo simulation that generates numbers using nrnd then does a unit root test on them. I have a series that runs from 1850 to 1968 that I'm doing 10,000 monte carlo replications.
Table adf_stats For !i = 1 to 10000 series ppmtswn = ppm + 2.908 * nrnd freeze(monte,mode=overwrite) ppmtswn.uroot(exog=trend,adf) scalar t_value = @val(monte(7,4)) adf_stats(!i ,1)=t_value next
Is there some way I can run the unit root test on just part of the ppmtswn series. Just from 1860 to 1958?
Thanks for any assistance.
Re: How to Run unit root tests on part of a series?
Postby EViews Gareth » Sun Jun 21, 2015 1:16 pm
Set the sample with the smpl command prior to running the unit root test.
