Hi there,
I am new to EViews and wondering how I can difference my data.
I used Genr to transform my data by DData=D(Data). I do not know if it is the correct way to perform this.
Thanks and regards
Kalec
How can I do differencing in EViews?
Re: How can I do differencing in EViews?
That works. Take a look at both the original and differenced series as a check.
Thanks Startz
It may be a stupid question, but how can I check against the original data to see if the differenced data are correct?
Many thanks and regards
Kalec
Kalec
Display both the original series and the differenced series. Pick an observation as a spot check and be sure that the differenced series is the same as you get from subtracting one observation from another in the original.
By the way, you can also generate a differenced series with
series ddata = data - data(-1)Re: How can I do differencing in EViews?
Thanks so much Startz
Kalec
Kalec
