code for automatic data retrieval from source
vytama
Postby vytama » Tue Jun 04, 2013 11:46 am
I use Eviews 8. I would like to setup a code to create and later be able to update series from source. For instance, I heard that Eviews "communicates" with Haver Analytics. I was wondering if it is possible to set up with Moody's Analytics' Databuffet.com or Reuters' Datastream? I would like to create a code which would automatically pull updates into Eviews.
Thanks.
Vytas
Re: code for automatic data retrieval from source
Postby EViews Gareth » Tue Jun 04, 2013 1:08 pm
Yes, we have built in support for Datastream, and Moody's Economy.com data. Both require the Enterprise version of EViews, and an account with the data providers.
You can use the fetch command to fetch data from those providers into your EViews workfile.
vytama
Postby vytama » Tue Jun 04, 2013 1:24 pm
Thanks, I have to check if I have enterprise version. with Fetch command - do I use moody's economy.com mnemonic for the series?
I have just looked up fetch command in help section - it does explain how to get data from database, but it does not explain how to get from outside data provider (moodys). Could you provide more info on that or tell where I could read more about it? Thanks
Vytas
Postby EViews Gareth » Tue Jun 04, 2013 1:28 pm
The easiest way to do it is to register your Moody's account in the EViews database registry, then use the fetch command to fetch from the name you've given that database. You can read all about the database registry in User Guide I.
vytama
Postby vytama » Tue Jun 04, 2013 1:38 pm
great, thank you.
vytama
Postby vytama » Mon Aug 05, 2013 6:54 am
Hi, So we upgraded Eviews 8 to enterprize edition. When I go to Database registry entry window and select Database/file type as Moody's economy.com and specify the path and alias, the user name and password field is greyed out - I cannot enter my user and password? Is there something that I am missing?
Postby EViews Jason » Mon Aug 05, 2013 9:34 am
EViews will read Moody's Economy.com database files. These are local or network accessible (*.fdb) files. From what we gather, these files do not require a password or username. EViews currently does not support the download of Moody's data directly from their web servers (EViews does however support Datastream web server data retrieval). To use Moody's data you would have to first obtain the latest *.fdb files and fetch the data from there.
vytama
Postby vytama » Mon Aug 05, 2013 9:52 am
Do I need to obtain (*.fdb) files from Moodys?
Postby EViews Jason » Mon Aug 05, 2013 12:01 pm
Yes
lisatt
Postby lisatt » Wed May 27, 2015 6:46 am
Hi Jason,
I am a new Eviews 8 user and I try to work with both Eviews and Datastream. The "fetch" command to import my series directly from Datastream to Eviews worked well. I was wondering if there is a command to fetch the entire "Name" of the Datastream series directly to Eviews as well?
Many thanks!
Postby EViews Jason » Wed May 27, 2015 10:14 am
If you open the downloaded series from within your workfile and then select view->label, you should see the original name in the history section
lisatt
Postby lisatt » Thu May 28, 2015 8:53 am
Great, many thanks! Is there any possibility, in a program, to assign the description/name of a series to the graph of the same series, as a title for example (addtext? or graph.label...?) ?
Thanks!!
Postby EViews Gareth » Thu May 28, 2015 9:18 am
Set the displayname of the series to the text you want to use in the graph.
