Hi all,
I am coding VAR estimations on EViews 7.2 and would like to set some coefficients to zero (that I find statistically or economically non-significant).
I only found the function .append but it seems to be reserved for cointegration (argument coint) or Structural VAR (argument svar)
Is there a way to restrict coefficients in case of simple VAR ?
Thanks in advance for your help.
Coefficient restrictions VAR
Re: Coefficient restrictions VAR
No, although you can make a system out of the VAR and impose restrictions on the system coefficients. Proc->Make System.
You'll only be able to see the coefficient estimates though - you won't be able to do things like impulse responses.
Thanks for your prompt reply Gareth.
If I want to use the code and not the toolbox (I have many similar VAR to estimate), can I code a system and its Impulse Response function associated like for a VAR ?
Systems don't have impulse responses built in, but you could always program it yourself, I guess.
