Hello. I am using Eviews9(64bit-version Standard Edition May 20 Build), and found the following phenomenon.
When I run the following two-line program in verbose mode,
smpl 1985 2000
copy page1\ccc page2\ddd
where series ccc does not exist in page1, it returns error "CCC is not defined in "COPY PAGE1\CCC PAGE2\DDD".". But it does not return error when run in quiet mode. However, it does return error in quiet mode when the first line is replaced with "smpl @all".
(The same phenomenon happens with Eviews8.)
Error suppressed in quiet mode
Re: Error suppressed in quiet mode
Could you provide more details?
If I run the following program:
It returns the same, correct, error whether run in quiet or verbose.
create(page=page1) a 1980 2000
'series ccc=nrnd
pagecreate(page=page2) a 1980 2000
If you add smpl specification right before copy command as follows
'series ccc=nrnd
smpl 1980 2000
it does not return error in quiet mode.
'series ccc=nrnd
smpl 1980 2000
Sorry, yes, my mistake. We'll fix.
