Coefficient Restrictions
Amaziah
Postby Amaziah » Fri Apr 24, 2015 7:49 am
Is it possible to restrict a coefficient to be a specific value or between a range of values? For example:
Y=a+a1X1+a2X2+a3X3+e ,
where I want the parameter estimate, a1, to equal 1.
I know how to test for linear restrictions, but not how to impose them.
Re: Coefficient Restrictions
Postby startz » Fri Apr 24, 2015 7:54 am
Wherever you have "a1" in the formula, type in "1" instead. (A range of values isn't so easy.)
Amaziah
Postby Amaziah » Fri Apr 24, 2015 8:34 am
Thank you. I am used to typing the equation in the following manner:
ls y c x1 x2 x3.
Am I able to impose this restriction in this format?
Postby startz » Fri Apr 24, 2015 8:35 am
ls (y-1*x1) c x2 x3.
Amaziah
Postby Amaziah » Fri Apr 24, 2015 8:51 am
Thank you very much. Where could I learn to restrict x1 to a range a values? For example, I want x1 to fall between .5 and 1.
Postby startz » Fri Apr 24, 2015 8:56 am
There is no general procedure for doing this in EViews. Sometimes you can figure out a translation of the parameter that accomplishes what you want. For example, substitute for a1
a1=.5+.5*exp(b1)/(1+exp(b1))
If b1 = -infinity, this gives you .5. If b1 equals infinity, this gives you 1.0. So the unconstrained value of b1 maps into the constrained value of a1.
Amaziah
Postby Amaziah » Fri Apr 24, 2015 9:04 am
Thank you very much. You have been extremely helpful.
Amaziah
Postby Amaziah » Fri Apr 24, 2015 9:44 am
Would I estimate the model in the following manner:
ls (y-.5+.5*exp(b1)/(1+exp(b1))) c x2 x3
Is there any way to do this so the a1 (or the translation of a1) will be listed as a independent variable in the results?
Postby startz » Fri Apr 24, 2015 9:52 am
Because you need to have explicit coefficients, the EViews syntax is probably something like
ls y = c(1) + (.5+.5*exp(c(2))/(1+exp(c(2))))*x1 + c(3)*x2 + c(4)*x3
You can find out the value of "a1" in a kludgey way by doing a Wald test for
(.5+.5*exp(c(2))/(1+exp(c(2))))=0
Amaziah
Postby Amaziah » Fri Apr 24, 2015 10:13 am
Okay. I should have been more specific from the beginning because I am proving not skilled enough to apply your solutions into my model.
I am trying to restrict a price variable based on the assumption that the own-price elasticity of demand is close to one, adjusted down for the proportion of net revenues from a specific product.
This is done because of a lack of remedies for endogeneity associated with the price variable (there are no acceptable instruments).
On the surface, I thought this would entail restricting the price coefficient to (-1+proportion of net revenues). I am unsure how to apply this formula in eviews.
I apologize for including this information earlier, but I didn't think it was necessary.
Postby startz » Fri Apr 24, 2015 10:17 am
You want to estimate a least squares problem subject to inequality constraints. I don't think EViews can do this. It can be done in a program like Matlab with a little work.
Amaziah
Postby Amaziah » Fri Apr 24, 2015 4:18 pm
Okay thanks. I'll look into that.
