Problem opening a database by double clicking on it
leah
Postby leah » Tue Apr 21, 2015 9:02 am
When I try to open a database by double clicking on it in windows explorer, a message pops up saying "EViews 9 has stopped working - A problem caused the program to stop working correctly..." The problem occurs regardless of whether EViews is already running.
This is with the April 20th build this time. Thanks!
Re: Problem opening a database by double clicking on it
Postby EViews Gareth » Tue Apr 21, 2015 9:04 am
If you try opening it from within EViews (File->Open Database), what happens?
leah
Postby leah » Tue Apr 21, 2015 9:18 am
That works, as does dbopen in the command line or a program. It's just opening edbs from windows explorer that causes problems.
Postby EViews Gareth » Tue Apr 21, 2015 9:20 am
All edbs, or a specific one?
leah
Postby leah » Tue Apr 21, 2015 9:25 am
All edbs, 100% of the time. I've tried it out on a bunch of machines running 9 and the same thing happens. It looks like dragging and dropping an edb into EViews if it's already running works though.
Postby EViews Gareth » Tue Apr 21, 2015 9:43 am
If you right click the file, select Open With, then select EViews 9?
leah
Postby leah » Tue Apr 21, 2015 10:37 am
Yup, that gives the same error.
Postby EViews Gareth » Tue Apr 21, 2015 10:41 am
32bit or 64bit EViews 9?
Also, were these databases created in EV9, or a previous version (if so, which one?).
We can't replicate... :/
leah
Postby leah » Tue Apr 21, 2015 10:49 am
This is 64-bit EViews 9. I've tried a bunch of databases that were created between now and 2011 and none of them work. We've kept up-to-date on versions, so that includes at least 7-9?
leah
Postby leah » Tue Apr 21, 2015 10:52 am
Also, this isn't causing any major problems for us - I just thought I'd mention it cause I noticed it.
