Is there a command I can use to get a string showing the "Estimation Equation" (i.e., the equation estimated with coefficients c(1), c(2), etc)?
In the attached workfile the equation object holds an equation estimated with least squares with breaks. Neither the command @varlist nor @spec gives the estimation equation, which i can see from View-Representations:
Estimation Equation:
DLOG(K6025/K4025) = @BEFORE("2004Q4")*(C(1) + C(2)*(LOG(K6025(-1)/K4025(-1))-LOG(PBK60(-1)/PBK40(-1))) + C(3)*DLOG(PBK40(-2)) + C(4)*DLOG(PBK40(-1))) + @AFTER("2004Q4")*(C(5) + C(6)*(LOG(K6025(-1)/K4025(-1))-LOG(PBK60(-1)/PBK40(-1))) + C(7)*DLOG(PBK40(-2)) + C(8)*DLOG(PBK40(-1)))
- estimation_equation.WF1
- (14.05 KiB) Downloaded 235 times
Re: string showing the "Estimation Equation"
I don't believe that is accessible, other than by freezing the representations view.
this works,
freeze(auxtest) adl604025.representations
%s=auxtest.@line(7)
but is the "Estimation Equation" always on line 7 for all different possible estimation techniques ?
%s=auxtest.@line(7)
My gut says no.
I'll see if we can add it as a data member for an upcoming patch.
excellent, thanks :-)
In the new Eviews version build april 14 it states on the info page that you have "Added an @eqest data member to equations that returns the string representation of the equation's estimates.". But how do you fetch this string?
the command show adl104045.@eqest does not work...?
Thanks for making this command available
%s = eq1.@eqest-
Actually, I made a mistake in the documentation. It is @esteq not @eqest
perfect, thanks again
t
t
