Short run coefficient of Panel Cointegration
vasilika
Postby vasilika » Thu Mar 27, 2014 3:07 am
I am working on estimating a Panel Cointegration equation using Eviews 8.
By applying the FMOLS I am able to get the estimation of the long run relationship between the variables.
how do I move to estimate the short run coefficients and the speed of adjustement coefficient for panels?
thank you.
Re: Short run coefficient of Panel Cointegration
Postby EViews Glenn » Thu Mar 27, 2014 1:09 pm
DOLS has short run adjustment coefficients, though they may not be the ones you want since they are conditional on the lead differences. Both FMOLS and DOLS focus on long-run coefficients.
You'd be best off just estimating a panel error correction model. There isn't one built into EViews, but my instinct is that it shouldn't be difficult to do manually.
vasilika
Postby vasilika » Fri Mar 28, 2014 1:40 am
would you help me with some steps on how to do it manually starting from the results of the long run ?
Postby EViews Glenn » Fri Mar 28, 2014 9:33 am
That's a bit beyond the kind of help that we can provide. A quick Google search of "panel error correction model" yields a host of references. The Westerlund testing framework is probably where you should look. It's basically Engle-Granger in a panel context.
Adeel Ahmad Dar
Postby Adeel Ahmad Dar » Fri Apr 10, 2015 2:14 am
can anyone tell me the correct results of Pedroni co-integration ?
