I've been working with Eviews for a week now, and today all the data on my files was set to NA. I tried re-importing the data from the excel file, but it didn't work. Neither did manually inserting the data into the series, as it all reverted to NA once I pressed enter.
Is there any way to fix this without an update? Whenever I try to update its says "This feature is blocked by your administrator". The build is EViews 8 - Jul 26 2013.
Thank you!
Cannot import/edit data - all is set to NA
Re: Cannot import/edit data - all is set to NA
If you provide the Excel file, with instructions on how you're bringing it in, we can try to figure out what is going wrong.
You can download an update manually:
http://www.eviews.com/download/download.html
Maria Lopes
I am having the same problem, but not because of updates.
When I try to import my data to make a dated panel all the values are NA. I thought this was because of having values equal to zero. But It still happens even if I restrict the columns of my data set.
Can you please take a look of what might be going wrong? I've been all day going back and forth trying to understand what I am doing wrong and my clock is ticking!
Thank you
Thank you
- Data to import as Panel Data.xlsx
- (253.53 KiB) Downloaded 399 times
If I drag that file on to EViews, I don't appear to get any NAs.
What is your version of EViews and build date? I had no problem bringing in the data and structuring it as a panel.
