hi,
I estimate of a certain equation and run a wald test on this equation.
I obtain an output showing some statistics, for instance
Test Statistic Value df Probability
t-statistic -2.066683 167 0.0403
F-statistic 4.271179 (1, 167) 0.0403
Chi-square 4.271179 1 0.0388
my problem is I have about a thousand equation to estimate and test.
the question is: is it possible to access and collect the values of these statistics by name (like I can do with the equation for example equationname.@dw) to fill in a table/matrix for my following calculations ?
thank you
accessing statistics of the wald test
Re: accessing statistics of the wald test
Look up the use of "freeze" command.
thank you very much for the suggestion,
I took it into account, but I was wandering if there is something more direct.
the problem in using a freezed table cell referred to by coordinates is that the layout of the table could potentially change (not in the wald test case however) so the value picked up could be the wrong one. if the value is referred by name this problem should not arise.
